ManualInputEnabled Property
The ManualInputEnabled property specifies whether manual credit card input is enabled.
    [boolean=] SiteKiosk.Plugins("SiteCash").Devices("CreditCard").
               ManualInputEnabled
    Boolean value that specifies or retrieves whether manual credit
    The following example shows whether manual credit card input is enabled in an alert window.
    creditcard = SiteKiosk.Plugins("SiteCash").Devices("CreditCard");
    ccardinfo = creditcard.CreateCardInfo();
    alert(ccardinfo.ManualInputEnabled);
