OnBusyStatusChange Event
Fires when the busy status changes.
    SiteKioskWindow.SiteKioskWebBrowser.OnBusyStatusChange = handler
    avb_Busy Boolean value that is true if the browser is busy. False if the browser is not busy.
    The following example shows an alert window each time the busy status changes.
    SiteKioskWindow.SiteKioskWebBrowser.OnBusyStatusChange = OBSChange;
    function OBSChange(avb_Busy)
       alert(avb_Busy);
