ActiveWindow Property
The ActiveWindow property contains an object representing the currently active window.
[obj=] SiteKiosk.WindowList.ActiveWindow
WindowInfo object that represents the active window.
The following example shows the current window handle in an alert window.
alert(thiswindow.Handle);
