ValidDuration Property
The ValidDuration property contains the number of seconds the account will be valid after the activation (first login).
Account.ValidDuration [=long]
Long value that specifies or retrieves the duration.
This property is constant.
Durations are a number of seconds.
The following example displays the number of seconds the first account will be valid after the activation.
account = SiteCafe.Server.Accounts.GetAccountByIndex(1);
alert(account.ValidDuration);
