GetExpiredAccounts Method
The GetActivatedAccounts method returns a range of expired accounts.
    [obj=] SiteCafe.Server.Accounts.GetExpiredAccounts(sTime, eTime,
           sAccount, maxCount, activated)
    sTime Long value that specifies the start time.
    eTime Long value that specifies the end time.
    sAccount Long value that specifies the start account.
    maxCount Long value that specifies the maximum number of accounts.
    activated Boolean value that specifies whether to return only active accounts.
    Returns an AccountsCol collection containing the specified accounts.
    The start and/or end time will be ignored if they are 0. Otherwise they are specified by the return value of the Date.getVarDate method divided by 1000.
    The following example displays the persistent status of the first expired active account.
    acs = SiteCafe.Server.Accounts.GetExpiredAccounts(0, 0, 1, 10, true);
    alert(acs.Item(1).Persistent);
