OnAccountChanged Event
Fires when an account changed.
SiteCafe.Server.Accounts.OnAccountChanged = handler
index |
Long value that contains the account index. |
flags |
Long value that contains the change flags. |
Possible flags are:
1 : inserted
2 : updated
3 : deleted
The following example displays the index and flags when an account changed.
SiteCafe.Server.Accounts.OnAccountChanged = OnAccountChanged;
function OnAccountChanged(index, flags)
alert("Account: " + index);
alert("Flags: " + flags);
