OnAdminChanged Event
Fires when an admin changed.
SiteCafe.Server.Admins.OnAdminChanged = handler
index |
Long value that contains the admin index. |
flags |
Long value that contains the change flags. |
Possible flags are:
1 : inserted
2 : updated
3 : deleted
The following example displays the index and flags when an admin changed.
SiteCafe.Server.Admins.OnAdminChanged = OnAdminChanged;
function OnAdminChanged(index, flags)
alert("Admin: " + index);
alert("Flags: " + flags);
