Item Method
The Item method returns one item of the collection.
[str=] SiteKiosk.CDRecording.AudioFiles.Item(index)
index |
Long value that contains the item number to return. |
Returns a String that contains the path of the audio file.
Collection-index values are 1-based.
The following example shows the path of the first existing selected audio file in an alert window.
if (SiteKiosk.CDRecording.AudioFiles.Count > 0)
alert(SiteKiosk.CDRecording.AudioFiles.Item(1));
else
alert("There is no selected audio file");
