PauseDevice Property
The PauseDevice property reads or sets the pause status of a ccTalk device.
    [bool=] SiteKiosk.Plugins("SiteCash").Devices("ccTalk").PauseDevice
    Boolean value. True if the device is paused.
    False if the device is active.
    The following example shows the current pause status of the device in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").Devices("ccTalk").PauseDevice);
    SiteKiosk v6.6 (and later versions).
