ActiveRecorder Property
The ActiveRecorder property contains the GUID of the active recorder.
    SiteKiosk.CDRecording.ActiveRecorder [=str]
    String that specifies or retrieves the GUID.
    The following example shows the GUID of the active recorder in an alert window.
    alert(SiteKiosk.CDRecording.ActiveRecorder);
