GetDirXml Method
The GetDirXml method returns the structure of a directory as an IXMLDOMDocument.
    [obj=] SiteKiosk.CDRecording.GetDirXml(path)
    path String that specifies the path of the xml file.
Return Value Remarks
    The IXMLDOMDocument contains all files and subfolders of the given path.
    The following example displays the structure of the main directory in an alert window.
    xmlDoc = SiteKiosk.CDRecording.GetDirXml("c:/");
    alert(xmlDoc.xml);
