JobActive Property
The JobActive property indicates whether a record job is currently active.
[bool=] SiteKiosk.CDRecording.JobActive
Boolean value that retrieves the activity status.
The following example determines whether a record job is currently active and shows it in an alert window.
alert(SiteKiosk.CDRecording.JobActive);
