MediaFlags Property
The MediaFlags property contains the flags of the current media.
    [long=] SiteKiosk.CDRecording.MediaFlags
    Long value that retrieves the media flags.
    Possible media flags are:
    MEDIA_BLANK = 1
    MEDIA_RW = 2
    MEDIA_WRITABLE = 4
    MEDIA_FORMAT_UNUSABLE_BY_IMAPI = 8
    Use the UpdateMediaInfo method to update this property.
    The following example shows the media flags in an alert window.
    alert(SiteKiosk.CDRecording.MediaFlags);
