OnAddProgress Event
Fires when the progress of adding files to the
AudioFiles collection changes.
SiteKiosk.CDRecording.OnAddProgress = handler
steps |
Long value that contains the completed steps. |
totalsteps |
Long value that contains the total number of steps. |
The following example displays the progress while adding files to the AudioFiles collection.
<div id="id_add">Adding: 0 / 0</div>
var lk_CDRecording = SiteKiosk.CDRecording;
lk_CDRecording.OnAddProgress = OnAddProgress;
function OnAddProgress(steps, totalsteps)
id_add.innerHTML = "Adding: " + steps + " / " + totalsteps;
