OnBlockProgress Event
Fires when the progress of writing blocks changes.
    SiteKiosk.CDRecording.OnBlockProgress = handler
    completed Long value that contains the number of written blocks.
    total Long value that contains the total number of blocks.
    The following example displays the progress of writing blocks when recording.
    <div id="id_block">Blocks: 0 / 0</div>
    var lk_CDRecording = SiteKiosk.CDRecording;
    lk_CDRecording.OnBlockProgress = OnBlockProgress;
    function OnBlockProgress(completed, total)
       id_block.innerHTML = "Blocks: " + completed + " / " + total;
