OnBurnComplete Event
Fires when the CD has been completely written.
    SiteKiosk.CDRecording.OnBurnComplete = handler
    status Long value that contains the status.
    The status is negative if the CD has not been recorded successfully.
    The following example shows the status after burning in an alert window.
    var lk_CDRecording = SiteKiosk.CDRecording;
    lk_CDRecording.OnBurnComplete = OnBurnComplete;
    function OnBurnComplete(status)
       alert("Burn status: " + status);
