OnMediaInserted Event
Fires when media has been inserted into a recorder's tray.
    SiteKiosk.CDRecording.OnMediaInserted = handler
    deviceletter DWORD value that contains the device letter.
    The device letter is a logical unit mask identifying one or more logical units. Each bit in the mask corresponds to one logical drive. Bit 0 represents drive A, bit 1 represents drive B, and so on.
    The following example shows the device letter when media has been inserted into a recorder.
    var lk_CDRecording = SiteKiosk.CDRecording;
    lk_CDRecording.OnMediaInserted = OnMediaInserted;
    function OnMediaInserted(deviceletter)
       alert("Media inserted into: " + deviceletter);
