OnMediaRemoved Event
Fires when media has been removed from a recorder's tray.
SiteKiosk.CDRecording.OnMediaRemoved = handler
deviceletter |
DWORD value that contains the device letter. |
The device letter is a logical unit mask identifying one or more logical units. Each bit in the mask corresponds to one logical drive. Bit 0 represents drive A, bit 1 represents drive B, and so on.
The following example shows the device letter when media has been removed from a recorder.
var lk_CDRecording = SiteKiosk.CDRecording;
lk_CDRecording.OnMediaRemoved = OnMediaRemoved;
function OnMediaRemoved(deviceletter)
alert("Media removed from: " + deviceletter);
