OnVolumeInserted Event
Fires when a volume has been inserted.
SiteKiosk.CDRecording.OnVolumeInserted = handler
deviceletter |
DWORD value that contains the device letter. |
The device letter is a logical unit mask identifying one or more logical units. Each bit in the mask corresponds to one logical drive. Bit 0 represents drive A, bit 1 represents drive B, and so on.
The following example shows the device letter when a volume has been inserted.
var lk_CDRecording = SiteKiosk.CDRecording;
lk_CDRecording.OnVolumeInserted = OnVolumeInserted;
function OnVolumeInserted(deviceletter)
alert("Volume inserted as: " + deviceletter);
