OnVolumeRemoved Event
Fires when a volume has been removed.
    SiteKiosk.CDRecording.OnVolumeRemoved = handler
    deviceletter DWORD value that contains the device letter.
    The device letter is a logical unit mask identifying one or more logical units. Each bit in the mask corresponds to one logical drive. Bit 0 represents drive A, bit 1 represents drive B, and so on.
    The following example shows the device letter when a volume has been removed.
    var lk_CDRecording = SiteKiosk.CDRecording;
    lk_CDRecording.OnVolumeRemoved = OnVolumeRemoved;
    function OnVolumeRemoved(deviceletter)
       alert("Volume removed: " + deviceletter);
