Name Property
The Name property contains the name of the code.
    Code.Name [=str]
    String that specifies or retrieves the name.
    The following example displays the name of the first available code.
    code = SiteCafe.Server.Codes.GetCodeByIndex(1);
    alert(code.Name);
