GetCodes Method
The GetCodes method returns a range of codes of this group.
    [obj=] CodeGroup.GetCodes(start, maxCount)
    start Long value that specifies the start code.
    maxCount Long value that specifies the maximum number of codes.
    Returns a CodesCol collection containing the specified codes.
    The following example displays the name of the first code group's first code.
    codeGroup = SiteCafe.Server.Codes.GetCodeGroupByIndex(1);
    codes = codeGroup.GetCodes(1, 10);
    alert(codes.Item(1).Name);
