Create Method
The Create method creates a code.
[long=] SiteCafe.Server.Codes.Create(name, accIndex, GrpIndex)
name |
String that specifies the code name. |
accIndex |
Long value that specifies the account index. |
GrpIndex |
Long value that specifies the group index. |
Returns a Long value containing the code index.
The following example creates a new code.
codeIndex = SiteCafe.Server.Codes.Create("NewCode", 1, 1);
