CreateGroup Method
The CreateGroup method creates a code group.
    [long=] SiteCafe.Server.Codes.CreateGroup(name)
    name String that specifies the group's name.
    Returns a Long value containing the code group index.
    The following example creates a new code group.
    groupIndex = SiteCafe.Server.Codes.CreateGroup("NewGroup");
