Delete Method
The Delete method deletes a code.
    SiteCafe.Server.Codes.Delete(index)
    index Long value that specifies the code index.
    The following example creates and deletes a code.
    codeIndex = SiteCafe.Server.Codes.Create("NewCode", 1, 1);
    SiteCafe.Server.Codes.Delete(codeIndex);
