DeleteGroup Method
The DeleteGroup method deletes a code group.
    SiteCafe.Server.Codes.DeleteGroup(index)
    index Long value that specifies the group index.
    The following example creates and deletes a code group.
    groupIndex = SiteCafe.Server.Codes.CreateGroup("NewGroup");
    SiteCafe.Server.Codes.DeleteGroup(groupIndex);
