GetCodeByIndex Method
The GetCodeByIndex method returns a code by index.
[obj=] SiteCafe.Server.Codes.GetCodeByIndex(codeIndex)
codeIndex |
Long value that specifies the code index. |
Returns a Code object representing the specified code.
The following example displays the name of the first code.
code = SiteCafe.Server.Codes.GetCodeByIndex(1);
alert(code.Name);
