GetCodes Method
The GetCodes method returns a range of codes.
[obj=] SiteCafe.Server.Codes.GetCodes(start, maxCount)
start |
Long value that specifies the start code. |
maxCount |
Long value that specifies the maximum number of codes. |
Returns a CodesCol collection containing the specified codes.
The following example displays the name of the first code.
codes = SiteCafe.Server.Codes.GetCodes(1, 10);
alert(codes.Item(1).Name);
