OnCodeChanged Event
Fires when a code changed.
SiteCafe.Server.Codes.OnCodeChanged = handler
index |
Long value that contains the code index. |
flags |
Long value that contains the change flags. |
Possible flags are:
1 : inserted
2 : updated
3 : deleted
The following example displays the index and flags when a code changed.
SiteCafe.Server.Codes.OnCodeChanged = OnCodeChanged;
function OnCodeChanged(index, flags)
alert("Code: " + index);
alert("Flags: " + flags);
