OnCodeGroupChanged Event
Fires when a code group changed.
SiteCafe.Server.Codes.OnCodeGroupChanged = handler
index |
Long value that contains the group index. |
flags |
Long value that contains the change flags. |
Possible flags are:
1 : inserted
2 : updated
3 : deleted
The following example displays the index and flags when a code group changed.
SiteCafe.Server.Codes.OnCodeGroupChanged = OnCodeGroupChanged;
function OnCodeGroupChanged(index, flags)
alert("Group: " + index);
alert("Flags: " + flags);
