Count Property
The Count property contains the number of codes.
    [long=] CodesCol.Count
    Long value that retrieves the number of codes.
    The following example displays the number of codes (maximum is 100).
    codes = SiteCafe.Server.Codes.GetCodes(1, 100);
    alert(codes.Count);
