Item Method
The Item method returns one item of the collection.
[obj=] CodesCol.Item(index)
index |
Long value that contains the item number to return. |
Returns a Code object representing the specified code.
Collection-index values are 1-based.
The following example displays the name of the first code.
codes = SiteCafe.Server.Codes.GetCodes(1, 10);
alert(codes.Item(1).Name);
