Count Property
The Count property contains the number of inserted coins.
    [long=] SiteKiosk.Plugins("SiteCash").Devices2.Item(index).Coins.Count
    Long value that retrieves the number of coin values.
    The following example shows the number of inserted coins of the first existing device in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").Devices2.Item(1).Coins.Count);
