OnComputerChanged Event
Fires when a computer changed.
SiteCafe.Server.Computers.OnComputerChanged = handler
index |
Long value that contains the computer index. |
flags |
Long value that contains the change flags. |
Possible flags are:
1 : inserted
2 : updated
3 : deleted
The following example displays the index and flags when a computer changed.
SiteCafe.Server.Computers.OnComputerChanged = OnComputerChanged;
function OnComputerChanged(index, flags)
alert("Computer: " + index);
alert("Flags: " + flags);
