GetComputerStats Method
The GetComputerStats method returns a range of statistics for a computer.
    [obj=] SiteCafe.Server.ComputerStats.GetComputerStats(compIndex, sTime,
           eTime, start, maxCount)
    compIndex Long value that specifies the computer index.
    sTime Long value that specifies the start time.
    eTime Long value that specifies the end time.
    start Long value that specifies the start statistics.
    maxCount Long value that specifies the maximum number of statistics.
Return Value Remarks
    The start and/or end time will be ignored if they are 0. Otherwise they are specified by the return value of the Date.getVarDate method divided by 1000.
    The following example displays the first computer's connection time of the first statistics.
    cStats = SiteCafe.Server.ComputerStats.GetComputerStats(1, 0, 0, 1, 10);
    alert(cStats.Item(1).ConnectTime);
