GetConnectedTime Method
The GetConnectedTime method returns the time a computer was connected.
[long=] SiteCafe.Server.ComputerStats.GetConnectedTime(compIndex,
sTime, eTime)
compIndex |
Long value that specifies the computer index. |
sTime |
Long value that specifies the start time. |
eTime |
Long value that specifies the end time. |
Returns a Long value that contains the time.
The start and/or end time will be ignored if they are 0.
Otherwise they are specified by the return value of the Date.getVarDate method divided by 1000.
The following example displays the time the first computer was connected.
alert(SiteCafe.Server.ComputerStats.GetConnectedTime(1, 0, 0));
