BackupDirectory Property
The BackupDirectory property contains the automatic backup directory.
SiteCafe.Server.Config.BackupDirectory [=str]
String that specifies or retrieves the directory.
The following example automatically creates a backup at 9:00 o'clock.
SiteCafe.Server.Config.EnableBackups = true;
SiteCafe.Server.Config.BackupCopies = 1;
SiteCafe.Server.Config.BackupDirectory = "c:\backups";
SiteCafe.Server.Config.BackupHour = 9;
SiteCafe.Server.Config.BackupMinute = 0;
