BonusActivated Property
The BonusActivated property indicates whether bonus is active (surfmiles).
    SiteCafe.Server.Config.BonusActivated [=bool]
    Boolean value that specifies or retrieves the bonus status.
    If bonus is active, the user gets a bonus when he spent a specified amount.
    The following example displays bonus information.
    if (SiteCafe.Server.Config.BonusActivated)
       multiplier = SiteCafe.Server.Config.BonusMultiplier;
       amount = SiteCafe.Server.Config.BonusAmount;
       limit = SiteCafe.Server.Config.BonusLimit;
       alert("Amount: " + (amount * multiplier));
       alert("Limit: " + limit);
