BonusAmount Property
The BonusAmount property contains the bonus amount.
SiteCafe.Server.Config.BonusAmount [=double]
Double value that specifies or retrieves the amount.
When the spending of the user reaches the limit, he receives this bonus amount.
The following example displays bonus information.
if (SiteCafe.Server.Config.BonusActivated)
multiplier = SiteCafe.Server.Config.BonusMultiplier;
amount = SiteCafe.Server.Config.BonusAmount;
limit = SiteCafe.Server.Config.BonusLimit;
alert("Amount: " + (amount * multiplier));
alert("Limit: " + limit);
