Debug Property
The Debug property indicates whether debug mode is active.
    SiteCafe.Server.Config.Debug [=bool]
    Boolean value that specifies or retrieves the debug status.
    The following example displays the debug status.
    alert(SiteCafe.Server.Config.Debug);
