EnableBackups Property
The EnableBackups property indicates whether automatic backups are enabled.
    SiteCafe.Server.Config.EnableBackups [=bool]
    Boolean value that specifies or retrieves the
    automatic backup status.
    The following example automatically creates a backup at 9:00 o'clock.
    SiteCafe.Server.Config.EnableBackups = true;
    SiteCafe.Server.Config.BackupCopies = 1;
    SiteCafe.Server.Config.BackupDirectory = "c:\backups";
    SiteCafe.Server.Config.BackupHour = 9;
    SiteCafe.Server.Config.BackupMinute = 0;
