EnableCodes Property
The EnableCodes property indicates whether code login is enabled.
    SiteCafe.Server.Config.EnableCodes [=bool]
    Boolean value that specifies or retrieves the code
    login status.
    The following example determines whether code login is enabled and displays it.
    alert(SiteCafe.Server.Config.EnableCodes);
