EnableMoney Property
The EnableMoney property indicates whether money mode is enabled.
    SiteCafe.Server.Config.EnableMoney [=bool]
    Boolean value that specifies or retrieves the
    money mode status.
    Money mode means that the credit will be decreased (prepaid).
    The following example determines whether money mode is enabled and displays it.
    alert(SiteCafe.Server.Config.EnableMoney);
