EnableTime Property
The EnableTime property indicates whether time mode is enabled.
SiteCafe.Server.Config.EnableTime [=bool]
Boolean value that specifies or retrieves the time mode status.
Time mode means that the remaining time will be decreased (prepaid) or the time will be increased (payment after surfing).
The following example determines whether time mode is enabled and displays it.
alert(SiteCafe.Server.Config.EnableTime);
