EnableUsers Property
The EnableUsers property indicates whether username/password login is enabled.
SiteCafe.Server.Config.EnableUsers [=bool]
Boolean value that specifies or retrieves the username/password login status.
The following example determines whether username/password login is enabled and displays it.
alert(SiteCafe.Server.Config.EnableUsers);
