ExpandPathVariables Method
The ExpandPathVariables method expands a string's path (and system) variables.
[str=] SiteKiosk.Config.ExpandPathVariables(varStr, sysVars)
varStr |
String that specifies the string containing variables. |
sysVars |
Boolean value that indicates whether also to expand system variables. |
Returns the given String with expanded path (and system) variables.
Notation of SiteKiosk variables: $(...)
Depending on the local system, the string '$(SiteKioskPath)\skins' may be expanded to 'c:\program files\sitekiosk\skins'.
Notation of system variables: %...%
Depending on the local system, the string '%SystemRoot%\system32' may be expanded to 'c:\windows\system32'.
The following example displays the path of the SiteKiosk skins folder.
folder = "$(SiteKioskPath)\skins";
folder = SiteKiosk.Config.ExpandPathVariables(folder, false);
alert(folder);
