GeneralizePath Method
The GeneralizePath method generalizes a string containing paths.
    [str=] SiteKiosk.Config.GeneralizePath(pathStr)
    pathStr String that specifies the string containing paths.
    Returns the given String with path (and system) variables.
    Notation of SiteKiosk variables: $(...)
    Depending on the local system, the string 'c:\program files\sitekiosk\skins' may be generalized to '$(SiteKioskPath)\skins'.
    Notation of system variables: %...%
    Depending on the local system, the string 'c:\windows\system32' may be generalized to '%SystemRoot%\system32'.
    The following example displays the generalized path of the SiteKiosk folder.
    folder = SiteKiosk.SiteKioskDirectory;
    folder = SiteKiosk.Config.GeneralizePath(folder);
    alert(folder);
