UpdateInterval Property
The UpdateInterval property contains the update interval.
    SiteCafe.Server.Config.UpdateInterval [=long]
    Long value that specifies or retrieves the interval.
    By default, the update interval is 5 seconds.
    This means that the user could be able to surf up to 5 seconds longer than he is allowed to.
    The update interval can be increased/decreased if the server is slow/fast.
    The following example displays the update interval.
    alert(SiteCafe.Server.Config.UpdateInterval);
