UseMACIdentification Property
The UseMACIdentification property indicates whether to use MAC identification.
    SiteCafe.Server.Config.UseMACIdentification [=bool]
    Boolean value that specifies or retrieves the MAC
    identification status.
    The following example determines whether to use MAC identification and displays it.
    alert(SiteCafe.Server.Config.UseMACIdentification);
