OnProgressChange Event
Fires when the transaction progress changes.
SiteKiosk.Plugins("SiteCash").Devices("CreditCard").
OnProgressChange = handler
ID |
Long value that contains the ID of the transaction. |
cur |
Long value that contains the current progress. |
max |
Long value that contains the maximum progress. |
status |
String that contains the status text. |
The following example shows the current transaction information.
<div id="progressinfo">Start a transaction</div>
creditcard = SiteKiosk.Plugins("SiteCash").Devices("CreditCard");
creditcard.OnProgressChange = OnProgressChange;
function OnProgressChange(id, cur, max, status)
progressinfo.innerHTML = id + ": " + cur + " / " + max;
